Bugs
  • 1. When no graphics are selected, the Shape Builder automatically applies to all graphics in the document. If the document is complex, it can cause significant lag or even crashes. It would be better to restrict its operation to selected graphics only.
    2. Graphics within a clipping group show offset issues.
    3. When adding control points with Elastic Warp, deformation occurs unexpectedly before any user operation. Additionally, moving graphics with more than two control points using this effect causes lag, which needs to be fixed.
    https://youtu.be/zd-Rf9jjwAY?feature=shared
    0_1750431288136_卡顿.vstyler
    @monsterfox said in Bugs:
    The same happens with the Bucket Fill tool. This is by design, but yes, with complex graphics it can get slow. How about a notification?
    I will try to replicate this.
    I will try to improve this, but the effect will add some lag.
  • @VectorStyler Adding a notification could be a temporary remedy, but in the long run, my suggestion might be a better solution.
    This one is not a bug. The orange shape (for the Move Inside) is distorted with a Warp effect (small amount).
    When moving the green lines inside this object, the lines also become distorted, causing a small change on their shape.
